  #11 (permalink)
Old 08-26-2007, 06:52 AM
Peter Lindemann Peter Lindemann is offline
Senior Member
Methods to produce small particles....
Originally Posted by amigo View Post
Hi Peter,
I have read that article awhile ago actually and the version I read had comments from a company SilverGen.com, where they refute some of the claims made in the article. See for yourself: http://www.dreamweaver.ltd.uk/Electr...Lindermann.pdf
I also remember reading the excerpt from the "Practical Colloid Chemistry" book about "Colours of Colloidal Metals", again thanks to your find, that was an eye opener as well.
My question now is does the constant current matter or not in your opinion and experience?
I have built all kinds of circuits that regulated current, switched polarity and what not and ran dozens of tests with half a dozen brands of distilled water. I found that the more complex electronics was and more science involved lesser was the TDS/PPM of my solution - go figure.
In the article you mention 30V as the best voltage for CS, so how would it work in the case of Radiant Oscillators or SG circuits that do not have fixed voltage per-se but are based on spikes?
Also, where do I find information and circuits for the solid-state Radiant Oscillators you mention? Why is that most people (even those who sell CS generators) still use standard battery/DC methods with current limiting instead of Radiant energy sources?
Many thanks!
Amigo,
Thanks for the link to my article "with corrections." Actually, the corrections are marketing statements to promote their constant current CS generator. My article was written in the spring of 1997. It was the first, authoritative article on the subject written to give the average person accurate information about how to make colloidal silver easily and safely AT HOME with a handful of batteries and some silver strips.
Clearly, the constant current units solve some of the batch consistency problems I was discussing, but it is NOT the only way to solve batch consistency and small particle size issues.
If the particles are so small that the CS remains clear and produces no Tyndall Effect when a laser is shined through it, then, technically, the silver particles are small enough to be considered "dissolved" and are beyond the official definition of a "colloidal suspension".
Back in 1998, we developed a method of making CS in distilled water that was treated multiple times with a Grander Water treatment system. This radically lowered the surface tension of the water BEFORE we made the CS. At that point, even using 30 VDC made particles so small they could penetrate every tissue of the body. A number of Doctors in Colorado developed a completely successful treatment for systemic Candida infection using this product. We sold this as a bottled product until the process was stolen from us by a major distributor.
So, I thoroughly reject the so-called "corrections" to my article. These statements are only relatively correct themselves and do not make my statements wrong within their context.
Peter
