Old 11-07-2009, 08:31 PM
FuzzyTomCat's Avatar
FuzzyTomCat FuzzyTomCat is offline
Silver Member
Send a message via Skype™ to FuzzyTomCat
TEST #8 "Clean Up" and "Mosfet Shunt"
Hi everyone,
Here is a short test after doing some recommended "Device Under Test" (DUT) circuit modifications ....
1) Prototype "Load Resistor" - remove circuit alligator test clips and connect with crimp-on wire ring terminals
2) Mosfet Source Pin - remove 3" wire extension wire for probe connection, probe now connected to Mosfet "source" pin
3) Battery Probe Connection - relocated to the common probe ground terminal connection point, Probe tip now twelve (12) inches from prototype "Load Resistor"
Channel 1 - Mosfet source shunt
Channel 2 - Mosfet drain
Channel 3 - 555 Timer pin #3
Channel 4 - 24 VDC "Liquid" Lead Acid Battery Bank
1_40us
"Snapshot with Math Functions"
1_40us_11_06_09.CSV Spread Sheet File
2_40us
2_40us_11_06_09.CSV Spread Sheet File
1_100ns
1_100ns_11_06_09.CSV Spread Sheet File
This is a test using only two oscilloscope probes with one probe tip on Channel-1 between the Mosfet and Shunt and Channel-2 between the Shunt and the Battery Negative (B-) terminal.
Both probe grounds Channel-1 and Channel-2 connected to a separate isolated AC ground point "NOT" to the battery negative (B-) terminal
Channel 1 - Mosfet Source to Shunt
Channel 2 - Shunt to Battery Negative
Channel 3 - 555 Timer Pin #3
(no probe connection - reference only)
MOSFET_SHUNT_BAT-N_555
MOSFET_SHUNT_BAT-N_555.CSV Spread Sheet File
All Images and data by a Tektronix TDS 3054C from the Tektronix Corporation
Glen
