  #4 (permalink)
Old 08-25-2007, 06:18 PM
Peter Lindemann Peter Lindemann is offline
Senior Member
My 2 Cents...
Originally Posted by amigo View Post
Hi Aaron,
Thanks for your reply.
I am still not sold out on the particles theory doing the "job". As you probably know there are two schools of thought, one is favouring particles, while the other is talking about ionic silver, where particles are not as predominant factor.
I think when we measure PPM in our home environments, we are actually measuring conductivity suggesting ions rather than particle concentrations. The only way to find out particle size and density would be under electron microscope and thus the company you mentioned claims 0.8 nm particle size - they had most likely done the electron microscope analysis.
In any case, I would appreciate suggestions from you or anyone else reading this on what would be the best approach to generating RE and using its potential as an energy source in the CS process.
Do I stick with SG motor and use that as a source, or are there better more suitable sources of RE? Should I rectify the potential or do I apply it directly without rectification?
Hi Amigo,
I built and sold Colloidal Silver Generators for over 10 years. This link takes you to an article I wrote for Borderlands Magazine back in 1997. Its a good background piece.
Colloidal Silver Generators | "A Closer Look" by Peter Lindemann
Please read this article before commenting further. It covers most of the issues you are discussing. I paid for the lab testing for particle size and total dissolved solids, and went back to the Chemistry books from 100 years ago to get the right answers.
I completely agree with Aaron. Particle SIZE is the most important issue. It has to do with two very import realities. First, by making the particles smaller, the total SURFACE AREA of the silver's interface with the environment gets larger. There are also more particles for the same concentration. Second, by making the particles smaller, they can PENETRATE more different kinds of tissue in the body, and get to more locations, producing a better, all around benefit.
Both John Bedini and I have experimented with making Colloidal Silver with his Radiant Oscillators. The particle size is super small and nothing ever precipitates after the solution is put in a brown bottle. The SG motor works fine, but the solid-state oscillators are simpler for this purpose. Use the standard, one diode, rectified output to the silver electrodes in distilled water.
Its cheap, its easy, and the product is excellent.
Peter
