  #3 (permalink)
Old 08-25-2007, 02:54 PM
amigo amigo is offline
Senior Member
Hi Aaron,
Thanks for your reply.
I am still not sold out on the particles theory doing the "job". As you probably know there are two schools of thought, one is favouring particles, while the other is talking about ionic silver, where particles are not as predominant factor.
I think when we measure PPM in our home environments, we are actually measuring conductivity suggesting ions rather than particle concentrations. The only way to find out particle size and density would be under electron microscope and thus the company you mentioned claims 0.8 nm particle size - they had most likely done the electron microscope analysis.
In any case, I would appreciate suggestions from you or anyone else reading this on what would be the best approach to generating RE and using its potential as an energy source in the CS process.
Do I stick with SG motor and use that as a source, or are there better more suitable sources of RE? Should I rectify the potential or do I apply it directly without rectification?
