  #1 (permalink)
Old 08-24-2007, 02:13 AM
amigo amigo is offline
Senior Member
Radiant energy and electrolysis (ionic/colloidal silver)
I'll stick this subject here since I do not know where else it might go and it sort of applies to alternative science.
For the past few months I have been experimenting with production of ionic/colloidal silver (from now on CS), trying to get as high concentration in PPM as possible. Basically we are conducting electrolysis of pure silver (99.99%) in distilled water (DW) to create a solution of silver ions (Ag+). Ideally we are looking for highest ionic concentration possible or highest particular solution.
If you look around there the Web, there are usual methods of creating silver colloid, either through DC (most common) or through AC current. Few weeks ago I got a crazy idea to try and use radiant energy as a power source for the process. So first thing I stumbled upon was JB's SSG and so decided to use that as a basic design and source of radiant potential. I liked the fact that the motor was self regulating to the load, so in this case it would figure itself out what it needs to provide for the electrolysis.
A consensus among CS enthusiasts is that you need to supply constant current to the circuit to achieve good PPM. Various people have built various circuits that do this, using anything from 12V up to 160V and more. The amount of current is computed by factoring the surface of the electrodes, and usually for home setups is between 500uA to 2mA.
Now I understand that in the orthodox approach a current is needed for the process but after seeing talks about Radiant H2O it made me think that RE could be applied in this case and possibly produce some results.
Since most of you here have more experience with RE sources than me, I would appreciate feedback on what would be the best way of approaching this matter (electrolysis of silver for production of CS), things like what would be an ideal source of RE (right now I thought of using SG but if there is a better one please advise); what's your take on anything actually happening; should RE have to be rectified or not (pulses exist in both cases but one is DC and the other is AC potential, no?) ...
If you need more details about CS here is a link I usually use as a reference or you can just google for colloidal silver and get tons of other links:
SilverSol - Silver Ions in Solution
Thanks.
