resistance
Hi Shamus,
On John's coils, I believe he uses about 100 feet per wire.
For the pots, you can put one in line with a resistor. Hook a scope to it. When you slowly start turning your wheel you might see 4 spikes per pulse...when up to speed you only want to see 1 spike per pulse...turn the pot until you only get 1, measure the total resistance, then replace with fixed resistor of the closest value to the tuned resistance. If you don't have a scope, you can use a radio or something else to hear or see the spikes.
1374 is quite high and if you hear noise from the coil, it is self oscillating...definitely needs less.
Also, can tune the circuits with a bulb in line with the resistor. I'll find reference for this. Also, can put 90v neon bulb across the collector and emitter as protection.
