Old 10-20-2009, 09:21 PM
witsend witsend is offline
Gold Member
Copied over from OU.COM.
Poynt. There are empirical measurements of both power dissipated and power delivered. Did you even read Harvey's post written almost exclusively for your benefit? post no 2077 page 208.
In any event. Here's the thing. There is no confusion with the computation of power delivered and power dissipated provided that the former is done in line with some dc coupled evaluation of energy delivered and the latter is done with reference to the rate of temperature rise. Both are impirical measurements but they fall short of MH's need for some balanced reconciliation of all power measurements. The fact is that there is a hugely complex sum in the computation of the inductive reactance across the load resistor and this is possibly required. I'm actually not sure that this will resolve all the questions though. Still outstanding is the fact that the positive voltage at the drain is in synch with the energy evidently returned to the system and as measured in the shunt on the source. And they are 'out of step'.
My own suggestion - for what it's worth - is that the circuit is pointing to some phenomenon that may have been overlooked by mainstream. I'm well aware how offensive this will read to all those who feel that there are no outstanding questions in electromagnetic interactions. But there are. There are many questions. I've covered these - ad nauseum - in my complaints against conventional explanations of current flow. And it's definitely out of context to enter into a discussion of that here. But what is is appropriate is to point to the waveform and acknowledge the discrepancy.
I'm afraid you cannot logically dismiss all the numbers simply because you cannot do a full power integration of the energy over the load resistor. With respect. This number may yet be resolved if someone can bend their mind around that complex math. But the fact remains that the voltage over the source and drain are diametrically opposed to each other. I sincerely believe that the discrepancey or, as you and MH have termed it, the puzzle, or the mystery needs to be unravelled at this very point. And I'm not sure that it will be a conventional explanation. But I'm open to correction.
