Old 10-05-2009, 09:19 AM
FuzzyTomCat's Avatar
FuzzyTomCat FuzzyTomCat is offline
Silver Member
Send a message via Skype™ to FuzzyTomCat
Rosemary Ainslie COP>17 Heater Circuit - TEST #2
Hi everyone,
Here is the second test of the Rosemary Ainslie COP>17 Heater Circuit replication of the "Quantum" October 2002 article.
It also includes a set of Mosfet Drain 360 Volt spike images and data (spread sheet) .CSV files
All Images and data from the Tektronix TDS 3054C from the Tektronix Corporation
TEST #2
Replication Components -
1) International Rectifier - IRFPG50 HEXFET® Power MOSFET
w/ Sil-Pad insulator between Mosfet and Heat Sink
2) Fairchild Semiconductor - NE555N Timer
3) Vishay Spectrol - SP534 Percision Potentiometer/ 10-turn 2-Watt
4) Exide Technologies Battery "Liquid Lead Acid" Model # GT-H - TRACTOR 12V 12Ah CCA 235
5) CSB Battery Company "Gel Lead Acid" #GP 1270 F2 / 12 Volt 7.0 Ah
6) Prototype - 10 Ohm resistor "Quantum Replication"
Temperature Measurements -
Fluke 62 "mini" IR Themometer ( used maximum reading on each componenet )
Digital Mulit Meter -
Fluke 87 DMM true RMS
Channel 1 - Mosfet source shunt
Channel 2 - Mosfet drain
Channel 3 - 555 Timer pin #3
Channel 4 - 24 VDC "Liquid" Lead Acid Battery Bank
2us Start
*Original 2us "Start" .XLR Spread Sheet File
2us_start .CSV file
20us Start
*Original 20us "Start" .XLR Spread Sheet File
20us_start .CSV file
2us Finish
*Original 2us "Finish" .XLR Spread Sheet File
2us_finish .CSV file
20us Finish
*Original 20us "Finish" .XLR Spread Sheet File
20_us_finish .CSV file
TEMPERATURE DATA SHEETS -
2us 360 Volt Spike
*Original 2us "360 Volt Spike" .XLR Spread Sheet File
2us_4_chan .CSV file
1us 360 Volt Mosfet Drain Spike
*Original 1us "360 Volt Spike" .XLR Spread Sheet File
1us_4_Chan .CSV file
400ns 360 Volt Mosfet Drain Spike
*Original 400ns "360 Volt Spike" .XLR Spread Sheet File
400ns_4_chan .CSV file
Glen
