  #5 (permalink)
Old 08-11-2007, 06:16 PM
Aaron's Avatar
Aaron Aaron is offline
Spiritual Entrepreneur
power source
Originally Posted by passion1 View Post
Aaron
Impressive amount of gas for 36W!
Did you use the setup as per Figure 1-1 (page 20) of the Stan Meyer technical brief?
What kind of stepup transformer and chokes have you used?
Passion1 (passionate about alternative energy!)
Hi Passion1,
They are t304 tubes with a 1mm gap in between the inside and outside tube.
For this amount of gas, I have used both a regular variac output through a bridge for dc and also the Bedini circuits.
I wound my own inductors on the + end and never used one on the - end. I was definitely able to get higher voltage for lower amps to the cell with the inductor. I have wound some with as little as 100 turns of about 26 guage magnet wire and I have also used a small spool of magnet wire about 100-150 feet long.
I'll post a simple variac schematic so that people can at least just make gas. After that works, then they can start working on the efficiency.
