Old 09-06-2009, 08:37 AM
FuzzyTomCat's Avatar
FuzzyTomCat FuzzyTomCat is offline
Silver Member
Send a message via Skype™ to FuzzyTomCat
You Tell Me ??
Hi everyone,
Well after watching my scope and DMM for hours now with the same results I am extremely pleased to show everyone the results from the last changes I made to the "Ainslie-Murakami Negative Dominant Waveform Generator" ....
1) Adding a insulator between the Mosfet and the Heat Sink eliminating the antenna effect
2) A new "Liquid" lead Acid battery
Exide Technologies Model # GT-H
TRACTOR
CUTTING EDGE
25 Reserve Capacity Minutes at 25 Amps
Cold Cranking Amps 235
12 Volt
Unit: each
Unit Weight: 15.0000 lbs
UPC Code: 017724265936
And the results are in ......
Starting voltage after purchase at store 2:30 pm PDT 12.67 volts, Start test after Mosfet Insulation between heat sink 7:30pm PDT 12.67 volts ........ Right Now 1:30 am PDT 12.69 volts after 6 HOURS ....... .02 volt increase above voltage at time of purchase ......
Glen
