  #16 (permalink)
Old 08-07-2007, 10:37 PM
Aaron's Avatar
Aaron Aaron is online now
Spiritual Entrepreneur
congrads!
Glad you got it working!
A few things for the efficiency is that you want as weak as magnets as possible but strong enough to just induce enough to trigger the base and also you want as much resistance at the base as possible while still letting the minimum through just to trigger the base.
The magnets you have look like the radio shack ones with the hole in the middle? Probably fine. Before you added more winds, it might have been possible to get it to run if you double stacked those magnets (with the fewer winds).
When you replace the resistor to 680, if it seems like it is difficult to get started, you can just double stack the magnets.
Anyway, post your results...looking forward to it. Also, you might see that when it gets going, it will speed up and start drawing up to the 1/4 amp you see, then it might start speeding up even more and the input might start dropping backwards. Kind of like shifting into higher gear but input drops.
I'll post a video of my roller skate wheel video...has about 600 turns. That is the very first one I ever did and it got me hooked! LOL
