08-05-2007, 06:37 AM
Spiritual Entrepreneur
LJ100 | Tongkat Ali | Eurycoma Longifolia - LJ100.com official discussion forum
Welcome to the LJ100.com official discussion forum. LJ100
Feel free to post questions, comments or simply engage in conversation about LJ100, Tongkat Ali - Eurycoma Longifolia.
Below is a little bit about this amazing herb.
LJ100 (Longjack - Eurycoma longifolia) is the strongest extract of Tongkat Ali currently available to retail. It was developed over 20 years of research isolating the active ingredients in Tongkat Ali and another 2 years developing a the highest technology in safe and effective commercial extraction.
Proven Effective for Significant Androgen Increase
Most studies quoted on testosterone boosting effects of Tongkat Ali are actually quoting LJ100 (Longjack - Eurycoma longifolia) results. This is because the research team, led by the scientist Professor Johari Mohd Saad, Ph.d., Dr. Ismail Tambi, and Dr. Azizol Abdul Kadir are at the forefront of Tongkat Ali research and only use the LJ100 (Longjack - Eurycoma longifolia) Extract in their studies.
What Makes LJ100 (Longjack - Eurycoma longifolia) So Unique?!? -
Proven Effective for Androgen Increase -
Standardization of Active Components -
Gentle on the Liver & Proven Safe -
Developed by the Top Researchers of Tongkat Ali -
Company Dedicated to Research Building on the traditional water-soluble extraction, the powder uses approximately 100 parts of the highest quality aged root (5-10 years old) to create only 1 part of extract. The extract process will also pull out phenolic components, tannins, high molecular weight polysaccharide, mucopolysacharides, from this fiberous plant.
Standardization of Active Componants
LJ100 (Longjack - Eurycoma longifolia) is superior in efficacy and quality. It was created by scientists who have been working on Tongkat ali Research since the early 1980's. For this reason, ONLY LJ100 (Longjack - Eurycoma longifolia) is standardized with 20-22% glycoproteins AND 40% glycosapaneins. The glyco-protein is patented and known to be responsible for the testosterone boost.
In the extract form, you need significantly less powder per dose and will get a more specific testosterone boosting effect. LJ100 (Longjack - Eurycoma longifolia) dosage is standardized based on pharmacokinetic studies and observations. In human clinical studies, it has been found that a 200mg dose will double serum testosterone levels by 2x increase in 2-3 weeks. There is also a 45+% boost in DHEA levels. Results have been reconfirmed by several independent labs in the United States.
Proven Safe, Proven to be Gentle on the Liver
LJ100 is has passed all toxicology tests. Scientists and researchers have confirmed that this extract. This herb is completely safe and non-toxic, even at doses 1,000+ times larger than the recommended suggested dose.
When extraction is done properly, impurities and non-essential compounds are removed from the herb. This is particularly true of tumors and roots like Tongkat Ali. For this reason, this extract (Longjack) is gentler on the liver than raw powder and even other extracts of Tongkat Ali. Indeed, BEWARE imitation extracts. If extraction is NOT DONE Properly, This herb is highly prone to fungal growth. Such toxicity would be seen via increased activity in the liver.
This extract (Longjack - Eurycoma longifolia) is the direct result of a project that started in the 1980s to promote one of Malaysia's richest treasures; it's rainforest. The makers of this incredible extract(Longjack - Eurycoma longifolia) works with this original group, known as Forest Research Institute of Malaysia (FRIM) and its original and top researchers.
Company Dedicated to Research on Tongkat Ali
This extract (Longjack - Eurycoma longifolia) is truly a complicated gift from Mother Nature. The makers of this extract (Longjack - Eurycoma longifolia) are dedicated to continued studies on this herb. Research is on-going. We are happy to answer your questions on the root.
For more information, visit LJ100 | Tongkat Ali - Longjack, Eurycoma longifolia
LJ100.com is an Energetic Forum partner and is using this forum as its official discussion forum.
