  #3 (permalink)
Old 08-01-2007, 08:46 PM
Aaron's Avatar
Aaron Aaron is offline
Spiritual Entrepreneur
Secret of Law of Attraction 3
TIME COMPRESSED ENERGY
If you put 10 parts energy into manifesting your desire over 10 days, that is 1 part energy per day. If you put 10 parts energy into manifesting your desire over 5 days, that is 2 parts energy per day. If you put 10 parts energy into manifesting your desire in one single day, that is 10 parts energy per day.
This may seem that there isn't much difference as long as a certain amount of energy is going into something. But, there IS! For very powerful results, you must use TIME as energy itself. Compressing as much work into the smallest unit of time possible will give you the most powerful results. TIME COMPRESSED ENERGY.
If you obsess over something day and night every waking hour for a couple weeks on a certain subject, you will attract to yourself people, events, books and other things that are in alignment with what you want to learn in a very powerful way. It will be way more powerful that if you took the same effort and expended it months or years. Take advantage of TIME energy. This concept alone will amplify all your results from your efforts beyond belief.
Take some water and drop one drop at a time and drop it on a rock below. It may take years to even notice any wear. Take all that water and squeeze it out a small hole with high pressure in a small amount of time and you will cut that rock like a laser beam.
Take a hammer and barely touch a window with it. You can do this 1000 times and still not break the glass. However if you take all that effort and compress it into a small blip of time, when you touch the window with it, it will shatter into dust. As a matter of fact, when taking advantage of time compressed energy, you may only need 10 taps of a hammer worth of energy if it is discharged in one single impulse to turn the window to dust verses what 1000 wimpy taps will do.
Why? Nature abhors a vacuum and it abhors strong gradients. If you put a small amount of potential into something, nature will cause it to dissipate until it is in equilibrium with its environment and there is nothing left. Basically, it comes into balance. Put another small amount of potential into something and this repeats. It might take forever to even be able to build the potential fast enough before nature equalizes it. But, if you put high enough potential into a small unit of time over and over, it is way too fast for nature's slow response to equalize it and you will certainly attract your desire much more powerfully.
Why do most people fail in manifesting their desires? Besides the fact that most people apply the wrong principles, they really don't take it on strong enough or don't want it bad enough and therefore they don't put enough potential into a small enough unit of time for anything to come about anytime soon.
When desires do manifest powerfully, it happens through the path of least resistance. When people experience this, they find themselves in the right place at the right time. People usually call this SYNCHRONICITY!
