Old 07-15-2009, 04:03 PM
witsend witsend is offline
Gold Member
EgmQC - I need to endorse Armagdn03 here. Our paper shows what is well known as a Parastic Hartley Effect. It's a random oscillation that needs to be taken out of signal circuitry. It's well known and problematic. What has not been known is that it gives a remarkable overunity result as it applies to applications for heat.
The point is this. No-one seems to be able to duplicate that resonance. It is characterised by spikes that are entirely aperiodic - and it is, therefore, very tricky to compute. Hence the need for specialised measuring equipment.
Be that s it may - the overunity is defintely measurable at all frequencies and all duty cycles. Having said that there are some really fast frequencies where the benefit is lost. However I've referred to possible variations in that paper. Nor do you need the precise circuit diagram. The experiment was only chosen because of the extreme values shown. Not critical to repeat it. Let's at least familiarise ourselves with overunity and the methodologies we're using to prove this. That in itself is a huge learning curve. Then we can move on from there.
