Old 07-13-2009, 08:56 AM
witsend witsend is offline
Gold Member
TinselKoala - I see you still read posts on this forum - failing which I am sure that Ramset will copy and post for you if you no longer have access - I would like to re-iterate that I am sincerely sorry for blaming your interpretation of the inverted waveform if, as it seems, the switch was incorrect.
Abject apologies - for what it's worth. It is thanks to Joit that this matter has been cleared up. If you continue to do the experiment - I suggest you build your own 555 switch.
And for the record - the claim relates to a frequency that is variously described but best known as a Parasitic Hartley Effect. I have this information from experts. The point is that it is an oscillating frequency that is damped down or clamped out, not sure of the correct term - as it interferes with signals which is when it's manifest. We show that that effect adds to the efficiency when it is NOT clamped out.
BUT the flyback principle, whether with inductive resistors or resistors in series with inductors - always give evidence of a gain. It can be at any frequency tested between 60Hz all the way to and beyond 600kHz. All work - some with more efficiency than others - and at extreme frequencies - with losses rather than gains. It can use just about any variation of the flyback principles as described by gotoluc as a reticulated current. And it does not need the induced Hartley Effect to realise a gain. In other words you can get the over unity performance on periodic waveforms.
Nor do you need specialised MOSFETS. And you will always see a gain if you run batteries on control tests.
The misrepresentation of the 555 in the Quantum Article I think has been proved by Joit. I sincerely apologise for the error. Hopefully with this admission you'll at least continue with the testing. You see now how wide is my claim. You can then disprove it on many bases.
