Understanding the Take if Off Module
Understanding the Take it Off Module.
The Take it Off Module is the Module that has the largest variation in customer experiences.
(The above is a nice way of saying, we get rave reviews from some , and deep disappointment from others )
If it were not for the fact that over 70% of the people using this module experience such tremendous benefits, we would pull it from the product list.
This module went through extensive pre-release development and testing.
Since it has been released it has been "upgraded" several times, and these additions did help *some* who were not previously seeing results.
We have some people that report losing up to 15 pounds in 2 weeks, and others that report actually gaining fat, and everything in between.
How can this be?
The first step is to understand what this module is programmed to do.
Taken from the Full Description of the product (with notes):
This module is designed to assist a person in natural, healthy weight loss.
Two important points-
1. The key word is Assist, not do it for them. It is not a pill, it is designed to assist a person in their efforts to lose fat.
2. Natural, healthy weight loss. Depending on ones natural metabolism, how fast they gained the weight (they want to lose), it can be taken off quickly or over a period of time, but the key is that it is done naturally and in a healthy manner.
It addresses a wide cross section of issues on both a habitual level and a balanced body chemistry level.
Some may lose inches rather than actual pounds, because of overall muscle tonification and the conversion of fat to lean muscle mass, which weighs more than fat.
Issues addressed in this module:
· Desire to work hard to make ones body fit and trim (one has to follow through on the desire and actually work hard)
· Increased metabolism (to a healthy level, not one that stresses the body in order to lose weight fast)
· Increased energy (see above)
· Stimulation of energetic physical activity (see above)
· Increased muscle mass and tone (this will actually add weight, but lead to fat loss)
· Healthy pituitary gland functioning (healthy, not overactive)
· Better digestion (of course, this can only work with what is ingested)
· Balanced bowel flora (very important for long term health)
· Increased metabolism of adipose fat (cellulite) (to a healthy level)
· Increased production & utilization of chromium picolinate (to a healthy level)
· Desire to eat healthy foods (this can be very tricky*)
· Stimulates detoxification to reduce cellulite (can result in one feeling detox effects, and if one turns to "comfort foods" when not feeling well, that would be counter productive)
*There are some of us that are very independent thinkers, very stubborn, and/or naturally rebellious, and thus candidates for actually starting to eat worse after beginning use of this module. This is because we do not want to "eat healthy", or we certainly do not want to change our eating habits just because these unbidden thoughts pop into our conscious mind...so we rebel and "do what we want". This is part of the process and most will eventually start doing what they know is right for themselves.
This module will increase a person’s energy.
It is important when using this module to exercise, walking 15-20 minutes every other day is sufficient.
Without some sort of exercise outlet for the additional physical energy, it could manifest as irritability, or nervous energy.
Recommended Program Supplements:
· Spirulina
· Multi-Vitamin and Mineral Supplement
· Fresh Vegetables and Lean Proteins
· Exercise (minimum 15-20 min every other day)
· Balance between resistance training and aerobic training
Now that we understand what the Module is programmed to do, there is a basis for realistic expectations.
The second step in understanding the Take it Off Module is:
PATHS products, as a rule, are NOT designed to work quickly. They are designed to help a person from the inside out, naturally, organically. This Module falls squarely in that category. Here is a post that explains the typical steps one goes through when addressing an issue at its' very root:
PATHS and the road to better health
The Take it Off Module is a #1 AND a #3 type module referred to in the above post.
The third step in understanding the Take it Off Module is:
Every single one of us is different. We are unfathomably complex life forms. We all start at different points, physically, emotionally, and in the habitual thought pattern department. This can, and does, have an influence on how quickly we see benefits from this Module. It can also, in some instances, be such a strong influence, that even after months, no benefits are achieved. Thankfully, for most, this is a very small percentage.
Regardless of how you are feeling, or what you are experiencing after 1, 2, 3 or even 4 weeks, the odds are in your favor that you will begin experiencing benefits from this module.
However, if after reading and understanding the above, you do not believe the Module will accomplish what you desire, then we recommend you discontinue use of it.
The amount of work we put into developing and testing each Module is immense. (especially this one! ) We only want the very best for each and every one of you, and if we can help you on your journey, this is our reward.
Namaste
