Old 06-30-2009, 08:18 PM
Lambda Lambda is offline
Member
Actually, the ((RPM X 4) / 60) would be correct, as the formula I posted would put it in cycles per minute, and this corrects it to cycles per second, which is how it should be. Sorry about that!
I'm getting the same waveforms, both AC & DC that Pneuphysics has posted, but I'm not experiencing any of the effects, which I believe is due to the coil's impedance. The 4 coils are wound with a single 23 AWG, 550 turns per coil. Some wire came in today, so I can tri-filar it (22AWG) and then hopefully the coils impedance will fall inside the bell curve. Hopefully we can eventually figure out the bell curve John speaks of, where the peak is, and the thresholds to get inside of it.
Mike
