Originally Posted by Ghst
Martin My eyes only saw what you can see in the video. I told Electrotek that I expected to capture a shot of the tube with light emitting from the ends of the Brass semi-tube. But the video shows it as I seen it.Its weird that the Brass did not show up in the glowing Jar image. This allows you to see through the red image where the brass should be. But the carbon fiber arrow shaft and connecting wires did reproduce in the image. I think it would be imposable to get a pre-discharge without the main following discharge, Its like Tek said the image precedes the cause. Its also interesting that like Tek told me, It appears as if the light discharge is coming from the image, but not the real one.  This is really weird stuff!
Yes, I noticed the image is not being "projected" from the jar. It just appears out of nowhere. If it was projected you would see light coming from the slot in the brass. It's also interesting to note that with scalar waves emulating perpendicular to the wire, that the image is also doing this in relation to the spark gap electrodes and it's appeared to be shifted in the same direction or toward the grid electrode. This could be just because that the brass slot is facing this same direction, but since it doesnt look like it's projecting from the slot maybe not? It'd be cool if there was a way to rotate the slot in another direction and keep the grid electrode right where it's at and see if the image moves with the slot direction or if it stays shifted in the direction of the grid electrode.
