Old 06-20-2009, 06:22 PM
Michael John Nunnerley's Avatar
Michael John Nunnerley Michael John Nunnerley is offline
Gold Member
P:S:
Sorry Aaron can not help you, I am using an inductive resistive element which has a resistance of 63 ohms it is rated normally at 240v and 900watts and I have driven this with a square wave 14.8v at different frequencies and have found that I can obtain some strange results at certain frequencies and an amp draw of only 250ma which under normal conditions would be 3.7watts going in but I am getting near 9watts into the test fluid I have also found that different frequencies have different power outputs and occure at or close to the harmonic frequencies of the original that I started at. Still testing on my set up and when I have all the data that I require I will post the results.
Mike
