Old 06-11-2009, 11:04 PM
redeagle redeagle is offline
Senior Member
Originally Posted by dllabarre View Post
It took a while reading through this post, and all the other posts referenced from this post, to find this:
"The gas that went into the coil is coming back as a spike because it is time compressed. The aether provides a free inwards push on anything displacing it. So when a coil is charged, this free inwards push is what is snapping the potential back to the coil on disconnect so fast virtually with no opposition. And, while it snapped back, it creates a true vacuum meaning it is free of positive potential that can cause resistance and this sucks in more energy from the vacuum with it adding to the potential....so there is a gain in potential by this mechanism. The inward snap of the potential causes a negative pressure zone...it sucks in extra potential from the vacuum. This is what the spike is and why it brings back more with it."
"When the voltage potential comes back, it draws more potential to it from the vacuum, adding to the sum of potential, which then gets transferred to a receiver...battery, capacitor, whatever. Once this potential is gathered, it has to go through "forward conversion" then it can move to a lower potential to light a bulb or whatever and as the work is being performed, that work is what energy is. What was being stored? Time. That is why time (width) doesn't show up on the spike - TIME is being conserved within that voltage potential...you'll see some width if you zoom way in at the bottom but for all pracitcal purposes, it is a spike without current."
The above makes the most sense to me of any explanation I've read so far about "the spike" we see in the SSG circuits.
"If you get a chance, please read this by Eric Dollard:
Eric Dollard Notes (1986--1991)
Read the Introduction to Dielectricity and Capacitance on pages
26-29 in the pdf." VERY interesting read!
Thank you Aaron.
DonL
The high spike comes from the collapse of the magnetic field in the coil. It only appears as a spike because that's how fast the coil collapses. The force that's generating the spike is the same thing that generates electricity in any generator. Consider your traditional brushless ac generator. The voltage peaks BETWEEN the magnets. If the magnetic field were able to collapse faster it would show spikes much like the ssg. but the nature of generators the magnetics field collapses slower because the magnet is still present. In the SSG the force that generated the magnetic field is no longer present to slow down the collapse. Time cannot be altered as it is dimensionless. The time concept is much like the string theory in that it's just a theory and so far it only works on paper. You can get the same spike out of a standard generator coil. you momentarily short the coil at the point of maximum voltage. This super charges the magnetic core when the current flow stops the magnetic field collapses inducing voltage in the generator coil. The same thing can be done by pulsing dc into a transformer.
The question that remains is how does the em collapse channel the energy in heat. In order for the system to interact with the heat it must be carried by em waves. It's possible that all non shielded em systems interact with the ambient heat energy. And also possible that the kromrey converter interacts on a larger scale because of the rapid changes in flux potential. If heat is carried by a specific frequency of em wave then the kromrey converter would have to be precision tuned to tap that frequency that would explain the odd placement of bedini's magnetics and the amount of experimentation that was required to make it successful.
