Old 06-02-2009, 07:07 AM
dambit's Avatar
dambit dambit is offline
Senior Member
Send a message via Skype™ to dambit
Hi All,
Ok... First things first. The converter works.
The reason you are reading this and not seeing a video is because after 2 min of running the machine, another coil unspooled itself.
This is the only remaining design problem I am having, so I will bite the bullet and redesign the coil spools so that they can have an aluminium cover slide over the outside of them. This way I figure they will hold up and look a bit better too. For the short term I will simply cover the coils in heat shrink.
Before the coil shat itself, I did manage to get a couple of readings. Just by spinning the shaft with my fingers I can get upto 5V on the output. While the drive motor was running the meter registered 25V on the output. I had just hooked up a battery to charge and saw that it was indeed charging when the coil went.
Cheers,
Steve
You can view my vids here
http://www.youtube.com/SJohnM81
