Old 06-02-2009, 06:50 AM
Aaron's Avatar
Aaron Aaron is offline
Co-Founder & Moderator
measuring efficiency
Hi Hob,
In this particular circuit, the heat amount appears to be absolutely disconnected from the current or voltage so measuring the heat and converting that to an equivalent amount of "electricity" is probably the only honest way to do it.
The "rules" seem to be the same in most "overunity" systems.
In Bedini circuits, the output can't be truly measured but work in the battery on the output can be, etc...
This is just an idea, don't know how it play out but perhaps the heat can heat x volume of water from x degrees to y degrees hot. It is known how much energy in joules must be expended to raise a certain volume of water from one temp to a certain temp. Then a thermometer can just be sitting in the water.
