Old 05-30-2009, 06:54 AM
Paul Harmans's Avatar
Paul Harmans Paul Harmans is offline
Junior Member
Thanks again Steve, seems the right way, I suppose you are drilling a hole in the threaded rod to slide it in, and connect it to the axle? Do you use ball bearings on your axle? (Apologize for all my questions)
Friday evening I did find the correct motor, see picture. It is made in Germany and the specifications are:
VDO (brand name)
Antriebstechnik (drive technique)
Type: M48x50/T
Spannung: 12 V -
Drehzahl: 3050 1/min bei 10 Ncm (rpm)
Best. Nr.: 211310 (order nr.)
