Old 05-30-2009, 01:00 AM
dambit's Avatar
dambit dambit is offline
Senior Member
Send a message via Skype™ to dambit
Originally Posted by Paul Harmans View Post
Thank you Steve, same problem here in the Netherlands, no slip rings, no usable electric motor, no aluminum rods, no copper wire, no… today it seems you have to buy a full equipped car engine, because most of all those salesclerks knows the separate parts by name anymore. But alright, I have to make these slip rings myself.
I have the Energy From The Vacuum part 10 DVD, but I still have some questions. Maybe there will be more specific info (from John Bedini himself on his website?) about the exact dimensions of the vital parts. Do you know the diameter of the coils core? I guess the core will be a massif steel bar? Fixed onto the nonmagnetic axle.
Hi Paul,
For my coil cores I just randomly chose a 12mm diameter. The way I have designed it is to use 4 separate cores, each with a 1/4" threaded hole that is 10mm deep. The cores are then connected to each other through the shaft using 1/4" threaded rod. Both the cores and the rod are made from mild steel. The pic should make it clearer.
Cheers,
Steve.
You can view my vids here
http://www.youtube.com/SJohnM81
