Three Year Countdown <>
http://tinyurl.com/SpecialYears2012
There's two incredibly wrong design flaws in today's homes that have caused us to be dependent on foreign crude oil suppliers. Here's a sensible blueprint for salvation to escape the coming Wrath that is already increasing:
#1 is the circuit box needs to be reworked so that if the clothes washer is running the refrigerator or stove won't run, and if the stove is being used the hot water heater won't run til the stove is turned off. The current circuit boxes were designed from an
assumption crude oil-generated electricity would always be CHEAP. We found out different so an adjustment is called for soon, either a new circuit box design; or an add-on to the circuit box would be fastest as opposed to replacing every circuit box in America.
#2 is the hot water heater running just as soon as the water temperature drops below the heater element setting... because what happens is the water heater element keeps turning on all through the day constantly expending ENERGY ALL DAY LONG expecting any minute to get asked to wash the car. I already posted my answer to that =>
Save $3-$4oo a Year > Water+Heater+Taped+Pipe Slows Thermostat NOW Lowers Electric/Gas Bills Runaway Carbon+Footprint Costs Wrap+Pipe doityourself Tankless but CHEAPER which in a nutshell is to set the hot water heater element setting way down to around 65-70 degrees so the heater runs much less then to add a high temperature heat tape wrapped around the exit pipe bringing hot water into the home. It could be
equipped with a sound sensor to trigger it on the second any hot water spigot (faucet) is turned on anywhere in the house. In doing that the hot water heater has been converted into the equivalent of a
TANKLESS WATER HEATER FOR THE ENTIRE HOME. Presently the home water heater is stabbing the monthly electric bill for approximately 25-35%.
A smallish Wind-Solar unit sitting in the yard or atop a house should not have a problem generating 30% of the remaining electricity required by a home. As a general rule Wind and Solar alternate through the day, many times the Wind getting it up at night time or, when it turns cloudy and the sunlight drops.
Wind alone isn't enough. Solar alone -with the present inefficient devices available- isn't enough. But the two combined into a synergetic alliance
+ fixing the circuit box and the water heater
+ adding on a storage capability where the solar-wind combo unit could be storing electricity to cover peak home usage (in the evening), there just isn't any good reason why homes and apartments couldn't be
taken off the Main Power Grid 6-12 months from now, no reason at all.
And yet I would not disconnect homes from the Power Grid. I would keep the powerlines active as the Backup Power. Taking that a tiny step further, all the homes in every nation on Earth not just American homes could be
trickling electric current back into the Main Power Grid system, into the community City & Township substations, and being routed into industry & government buildings, filling street light needs. The Main Power Grid could be scaled down considerably.
So what's the difference?
As it stands now the national power grids are Jim Dandy terrorist targets but in converting the nations to
HOME-GENERATED POINT-OF-SERVICE ON-SITE POWER that situation ceases to be. When hurricanes or tornadoes knock out electric power and snow/ice storms and if the solar radiation spikes hard in 2012,
NO PROBLEM: HOMES AND INDUSTRY REMAIN POWERED UP.
America could be strong again once we stop suckling from a shared bottle|barrel|Alaskaoilpipeline of sweet crude that puts hundreds of thousands into an early cancer death grave and creates dead zones in the oceans where no living sea creatures can exist without going extinct. In fact, it is within our reach to lower these dangers to near zero
PLUS reduce the nation's overall carbon footprint
PLUS eliminate the fossil fuel dependence that is draining the Economy, to do all that
PLUS become stronger than at any previous time in American History,
all within 2-3 years time.
It isn't that the laws of nature don't exist; they just clobber us when we ignore them
just as the Hopi Indian prophecies said we white caucasian dummies would do. American Power was set up to make electric companies and investors fat paychecks not defend against invading hordes of terrorists or deal with a more violent climate destroying entire State power poles in one evening. Whatever happened to the atheists? They know the weak get culled from the herd.
We're being culled from the herd as long as we refuse to smarten up. Look at the beehives and the ants and the bats, the geese who have the sense to fly together in a flock. In the name of Freedom and Freedom of Choice we chose to "do it our way" and our way sucks rotten eggs. Freedom has a ceiling above which the needs of the many have to reign.
Do we as individuals alone have the power to stop incoming asteroids or meteors? No, that's the government's job and we know it. That's because there's a ceiling rule in effect. When that day comes when all hell starts dropping from the sky we won't have time to commission a Study, draw lots, give every company imagineable a portion of the money "to be Fair" to every single company.
Democracy has a ceiling or it becomes a free-for-all contest for handouts. When our head bumps into it there better be a stronger ceiling above it. Strengthening that ceiling had better be some better solar devices, better wind devices and Gravity Wheels inside the homes and apartments that are shielded from spiking solar flare radiation waves.
Only by doing these things can we walk through the coming furnace.
Otherwise we won't last when the Beekeeper turns on the blowtorch to our hive after deciding we aren't producing enough honey. It appears it has happened before. Maybe it has and maybe it has not. I would prefer not being the first time or the last but the One who Made us has
the right to un-Made us at His discretion. If we're going to continue being stupid (aka living according to decade's old rules that no longer apply) then maybe we lose our right to exist too.
Maybe we abdicate to the next homo sapiens.
Maybe our Rights came with an exclusionary clause or two that we have violated to live in this Ponzi Scheme Rockefeller and J. Paul Getty World. We painted ourselves into this jail (that we can easily undo with the few tweaks in this post) <> now we have to paint ourselves out of it and it probably should include plenty of
buckets full of prayers. One thing is abundantly clear though: we do not have 15-25-50 years to think about it. We squandered that time discussing Monica Lewinski's dynamic hold on President Clinton while his expert team of presidential physicians were letting him deteriorate towards a massive heart condition that damn near killed the man.
