Originally Posted by Digits
H2O
This is the last stage of the gas gun I still have to figure exactly what Stan wants in that last stage specially the last chamber in his drawing it show that there are a poitive and negitive voltage zones and there are a coil on the outside?
Things that are still lacking in the drawing is the nozzels of the water mist and the non combustable gases though they are minors.
I have drawn some sort of coil on the last stage though I am not sure how big or how thick the wiring and I presume there should be some sort of spark plug around there some where.
I have started to draft a Engeneering specific drawing of the gasgun showing where O ring should go in and slots to cut and where to fill with resin ect.
I am basically there I just have to get catalogs for specific sizes of parts to do my selection of materials and sizes.
Any coment good or bad will be welcomed.
Question when I induce compressed air into the system and every thing goes wel what can I expect to see from the proceced gas,will it burn if ignited mabe I should add water spray at the end wil it disotiate the water?
But I will show and tell when I have a device built for now hope you lkie the concept drawings.
Digits
http://www.energeticforum.com/images/smilies/thanks.gif
In my system the engines vacuum draws in the air through the Gas Processor, after the GP is the EEC, then the recirculated exhuast gases, and then I make the micro-capacitors with the water everything being sucked into the combustion chamber by the engines own vacuum. As you can see I bent the rules a lot for I made the system suit the car and not bypass the car existing system as Stanley Meyer did. I seperated all the needed componets. That's why I tell everyone to design their own for if you follow the rules it still will work and we will get many prototypes that all work. On the wire sizes you can vary the sizes of the wire to suit your needs. I love the design and the program your using, looks very sharp and impressive.
And no, it wont disotiate the water, remember the rule is to atomized the water and also put an image charge on it turning the droplets into micro-capacitors since water is polar. Like any type of fuel the better we atomize it the better it will mix with the air to be exploded. For just like gasoline if the injector malfuctions and shoots a stream of gasoline into the combustion chamber you pritty much lose that pistons power contribution to the engine, the same rules apply to water for use as a fuel.
