  #221 (permalink)
Old 04-08-2009, 12:51 AM
pmazz850 pmazz850 is offline
Member
Air pressure
So we need to create air pressure through the injector. Got it.
If you replace the spark plug with this injector how will you ignite? Wouldn't it be easier to add a port to inject the mixture into the cylinder and still retain the ignition system? Does the mixture have to be ignited immediately after the final voltage zone? can it travel through some sort of tube(after the final voltage zone) then be ignited?
Do you use a VIC in your circuit?
Thanks again for all your help!
I WON'T STOP TILL I'M FREE!!!!!!!!!
