  #219 (permalink)
Old 04-07-2009, 09:42 PM
pmazz850 pmazz850 is offline
Member
Originally Posted by h20power View Post
Hi pmazz850,
The EEC can be hooked up directly to the positive and pulse with the use of a PNP type FET. Depending on what you are hooking it up to the EEC be it the WFC or the GP it hooks up differently. On the GP it has it's own screen mesh grid, on the WFC it shares the positive electrode. And the function of what it does is not the same.
An example of the EEC for the GP
As you can see the EEC doesn't have a VIC coil, and I am using LED's same as Stanley Meyer did though the ones we have today are far more effienct than what Stanley Meyer has in his time. On the injectors you are correct, but that too can be altered. You can fully seperate the three and mix them in different ways and still get the same end results. There are even different ways it can be injected. That is why I set all of this up as an engineering/builders project challange, for there are many ways to skin this cat, and someone out there is bound to out do me
Hope that helped some,
h2opower.
So, the mesh grid doesn't make contact with the electrode. it just collects the free electrons, right?
I'm going with the gas processor not the WFC.
So the water mist needs to be laser injected and the non combustible gas should be ionized, correct?
I'm thinking of making one chamber for injecting light into the water and another for ionizing the non combusibles and the electron extraction.
Am I headed in the right direction?
Can the water and the ambient air be processed in the same unit?
Sorry for all the questions. I just want to make sure I fully understand before I build a prototype.
When you speak of 125psi, is that pressure all created by the water pump or is there some kind of air pressure needed?
Also should one of the chokes for the EEC be variable?
Thank you for the help!
