  #216 (permalink)
Old 04-06-2009, 09:42 PM
pmazz850 pmazz850 is offline
Member
h2o,
Is the EEC made in the same manner as the VIC pics you posted? If so, when you say that each bobbins cavity must match the primary's inductance, Does that hold true for the EEC circuit? I'm having trouble separating the two in my head. The circuit is similar except after the positive choke there is an amp consuming device.
Another thing, the voltage zone for ionizing is separate from the voltage zone at the end of the injector cause you want to ionize the air before it goes into the injector, right? Along with charged atomized water and recycled exhaust gasses.
Also are we using lasers or LED's?
Originally Posted by h20power View Post
As I said before the L1 + L2 method didn't work, it gave me three different resonance frequencies. Then I made another correcting that problem by matching the individual bobbin cavities inductances to that of the primary coil, but I didn't make two sets of chokes and the voltage output was too low. Then I made yet another and did things the way Stanley Meyer did it, and it worked out fine. I made the Transformer to hit resonance at 42.8K Hz but it actually hit it at around 42.7k Hz or something close. It was very hard to keep at reasonance for the tempreture swings would change everything. Then I had to put with getting the water from the same source all the time, so I scraped the whole idea of using the WFC.
The first time I hook it up too the cell it didn't work all that well, so I went back too the books for a long time. Once I added in the EEC it worked okay, but the gas was just hho, and it lacked the energy to do much with. So back to the books once again and I found out just what the Gas Processors true function was. Then I went on to figure out the water fuel injectors and what made them tick, just to see why Stanley Meyer had gotten rid of the WFC. I posted the key to making water for fuel a reality so that everyone could try it out on their own. Sure I left a lot out, but I already explained that position of why I did so. Just build the gas processor for with it you can make a smack booster run a car if you get up to the 7L/min level or more.
Copying a system only leads to failure, understanding a system leads to making that system suit what ever needs you want to use it for. I thought everyone would have figured that out by now. Strive for understanding not copying, for even Stanley Meyer says that anyone with skills in the prior arts can make the system work any way they like. He also says that the Gas Processor can be used on any type of fuel.
I know everyone wants to see a show, wants to be entertained, and/or a show of proof like Ravi. I am not that type of person. I would have the people think, try things, failing many times until they gained a true understanding of the technology, for that is how we learn best after all is it not? After posting the science and the math to back that up, I thought that would be the start of the energy revolution. I gave just enough information so that there would be many different types of working systems out there, not just my version or Stanley Meyer's version. Making this water for fuel technology even that much harder to keep down. For it would be coming from all directions working differently but working none the less. After I write my summary I am not sure if I will write anymore on this site again. I have a life to live enjoying my family and friends.
For the longest time something in me would not let me rest until I did what I did on this site. Now, I feel like moving on with my life and enjoying my family more, for I truly feel I have done my part. I know this will make some upset, but for those that understand what has been done here, freedom awaits them and they know it.
Take care everyone for I wont be writting again until I finish up my summary.
h2opower.
