  #215 (permalink)
Old 04-06-2009, 07:55 PM
h20power h20power is offline
Senior Member
Originally Posted by tutanka View Post
HI to all.. I don't think that meyer injector is an good solution.. in fact injector is creator of hydrogen inside to combustion chambre.. but how you know engine is a pump and you have no more time for create hydrogen for burn.. if you consider also other thing.. in fact electrolisys is based on ions (OH-/H+) .. more electrolyte more gas.. you use two electrodes.. one positive and the other negative.. but you can apply the same concept on water and air.. water is the negative electrode and air the positive electrode.. no difference from old electrolisys... if you use multiple stages of negative ions to water you add some electrons(ex:+4), if you use multipel stages of positive ions (ex:-5) you cut some electrons from oxygen.. of course you have to atomize water and respect amount of oxygen present on air (20%) .. and calculate right amount of water.. similar stechiometric value from gasoline/air.. but after if water ionizer and air ionizer are ok and mixed properly you have high amount of hydrogen H2.. if you start plasma discharge you transform H2 to H1 and have a complete reaction.. regards
This is incorect thinking, when I say "Mirco-mini" that is yet another way to break the bonds of the water molecule and it has nothing to do with Dr. Faraday type electrolysis. We all know that water is a dielectric liquid knowing this we know that all the rules of capacitance applies. As the dielectric liquid passes thru the voltage zones it picks up an image charge of the voltage that is on the capacitors plates of the injector. This image charge in then used to break the bonds of the water molecule by allowing the voltage to perform work. How? As the water molecules evaporate they lose size or that is to say the phyical area of the newly created miro-mini capacitors is decreasing at a rate faster than the relaxation time of the water molecule ability to lose the image charge they picked up. This is the very definition of how voltage preforms work.
Now there are two theories as to what is taking place;
One is the water molecules self destruct as the water molecules decrease in size due to the evaporation time is less than the relaxation time of water.
or
This creates hydronium ions ( H3O+) and these ions can't exist in waters' evaporate state thus releasing one or more ( H9O4+) mono atomic hydrogen atom per water droplet when the droplet size reaches a critical mass of not being able to support any hydronium ions. And the image charge picked up will not allow the hydronium ions to dissapate it's charge.
Again no one ever seemed to pick up on what Stanley Meyer was doing until now. He used two totally different ways to break down the water molecule that both were not apart of Dr. Faradays type of electronlysis. One breaks down the water molecule in a direct short condition and the other I just discribed. I know this is raining on a lot of peoples paraides but we have a revolution to kick off here and those personal views have to be tossed aside for the greater good. The main enemy is greed for if anyone has motives of greed this technology will not come out. Just think if I was greedy would I have posted the solution to Stanley Meyer's work? No, I would have kept it all to myself and tried in vain to buck the system, and the technology again would have been losted. Think about it.
h2opower.
