HI to all.. I don't think that meyer injector is an good solution.. in fact injector is creator of hydrogen inside to combustion chambre.. but how you know engine is a pump and you have no more time for create hydrogen for burn.. if you consider also other thing.. in fact electrolisys is based on ions (OH-/H+) .. more electrolyte more gas.. you use two electrodes.. one positive and the other negative.. but you can apply the same concept on water and air.. water is the negative electrode and air the positive electrode.. no difference from old electrolisys... if you use multiple stages of negative ions to water you add some electrons(ex:+4), if you use multipel stages of positive ions (ex:-5) you cut some electrons from oxygen.. of course you have to atomize water and respect amount of oxygen present on air (20%) .. and calculate right amount of water.. similar stechiometric value from gasoline/air.. but after if water ionizer and air ionizer are ok and mixed properly you have high amount of hydrogen H2.. if you start plasma discharge you transform H2 to H1 and have a complete reaction.. regards
