Hey H2O
Yes this is the gas gun I am bussy with the last stage of the process I'll post it soon. I am using Solidworks 2009 to draft with.
Then I will start adding detail to the drawing,like O rings and slots and grooves and will start assigning materials to all parts.
I do have a few questions though.I will have to insulate the tube cause there will be allot of volts there will a PVC housing work?
Can I use Perspex tubes instead of SS tubes, I have a HV supply about 3000 volts and I can charge a piece of paper through a Perspex rod. Then I dont have to cut slots insto the tubes (Like in the SS tubes case) and then have a hard time sealing the slot so gas wont escape through the window.
And one more Question I was drawing this nice project and it struck me what form should the gas be that enters the tube at the bottom? can it be just water mist,though then chances are that ambient air might have to be used to creat the mist(like a spraygun) or should it be HHO gas prduced the conventional way.I do not prever the latter one though.
As I find time I do my drawings and detail will follow soon then the hard part of constructing is next, So wish me luck and hope you guys are comming right.
I have a feeling that soon we be successful,and then we wil be posting of howmuch power our reactors are preducing instead of how to figure out Stans patents.
Digits
http://www.energeticforum.com/images/smilies/thanks.gif
