  #20 (permalink)
Old 03-07-2009, 03:38 PM
CloudSeeder CloudSeeder is offline
Senior Member
The forces generated by the ball as it rounds the hub ~wherever that is determined needed~ do not exert a crippling negative force on the Gravity Wheel. The reason being that those forces are pulling against the axle which is locked in place. The one force that does matter is when the ball is plummeted into the smack plate at Down Bottom Center.
That pushes the wheel one way and bounces the ball back (and inward toward the hub) which are BOTH desired effects. One motion yields two positives, and that dear sirs is exactly the kind of 200% Gain Physics you have to use to make the device work.
And that is precisely why I can know the device will work.
Mark, don't make this harder than it needs to be. Remember always in your mind the device is in motion from when it was first pushed off. The ball at the bottom is not generating start off energy but circular continuation energy. It is the force of the ball PLUS the momentum of the spinning wheel, not just the ball.
