  #9 (permalink)
Old 03-07-2009, 03:18 PM
CloudSeeder CloudSeeder is offline
Senior Member
Joit is correct when he says others are missing the finer points. People who glance at the Gravity Wheel and then burst from the starting gate to proclaim it can't work well, people like that have an agenda... and probably several layers of agenda that all adds up to MANKIND'S CONTINUING TO SUFFER UNDER THE WHIP.
My simple drawings leave a lot out. I kept them simple on purpose because the main principle I wanted to express is that #1 the device is a circular escalator and #2 everyone in Science is familiar with what the ancient Greeks called their "Golden Ratio" of Math. The curvature the ball follows up and over the hub is a golden ratio.
So while my device I admit screws with people's brains it is
very simple actually. It's multiple golden ratios in motion.
Which all means, Mark, is that I have designed a machine that has never been designed or built in all history of mankind ever. However, again as Joit correctly commented there's something else. The Gravity Wheel #1 does not have to have an axle all the way through and #2 if it does it can be VERY SMALL DIAMETER.
I used the large bearing to make the principles obvious; so since the axle doesn't even have to be there but two bearings one on each side, the Golden Ration can be lowered and will be lowered. I made it go high and loop over top the axle in order to make the Golden Ratio aspect clearly demonstrated. Point of fact is it won't go nearly that high. The orbital trajectory will still be used but it will not be required to loop that high over the center of the imaginary axle.
Good for you Joit and Mark! You both see the Science behind the Gravity Wheel is science used by NASA, the Japanese Ministry of Science and the Russians. I have not invented anything new, just a new application and combination of multiple principles
