  #129 (permalink)
Old 03-03-2009, 09:06 AM
FuzzyTomCat's Avatar
FuzzyTomCat FuzzyTomCat is online now
Senior Member
Send a message via Skype™ to FuzzyTomCat
Mike
Originally Posted by mlurye View Post
All,
I would recommend you to check patent #454622 by Tesla.
I do believe that this patent hiding more than just a simple lamp. And check recommended frequency for it.
Why did Tesla invent something that nobody could use unless he knew the way to provide energy required by this lamp in global scale?
Did anybody was able to repeat this patent?
Hi Mike,
That patent you found of Tesla's Is really something, excellent find. I have seen the wiring diagram at Colorado Springs Notes - Introduction but didn't pay much attention to it until now, a mistake it appears.
NIKOLA TESLA - Google Patents
"System Of Electrical Lighting" Patent No. 454,622 N. Tesla
Lines 44-49
As an instance of what I regard as the lowest practicable limits I would state that I have obtained fairly good results by a frequency as low as fifteen thousand to twenty thousand per second and a potential of about twenty thousand volts.
Lines 62-71
The carrying out of this invention and the full realization of the conditions necessary to the attainment of the desired results involve, first, a novel method of and apparatus for producing the currents or electrical effects of the character described; second, a novel method of utilizing and applying the same for the production of light, and, third, a new form of translating device or light-giving appliance.
The patent is complex in nature hard to read in a scene but significant to say the least the above two excerpts are only a few of many in this curious document of a "multi" use vacuum tube.
Humm ..... ether, cosmic-rays, vacuum tubes and KHz frequencies sounds like a very interesting mix .....
Glen
