Old 02-27-2009, 06:54 AM
nilrehob's Avatar
nilrehob nilrehob is offline
Silver Member
Originally Posted by boguslaw View Post
...so magnetic field of coil + magnetic field of iron core COLLAPSE..
I'm not sure that I follow. Do You mean that the forward EMF generated by the collapse of the field is boosted by the magnet going away?
Originally Posted by Jetijs View Post
If you want inductive spikes without any magnets involved, look at Bedini self oscillator circuits or Peters rotary attraction motor.
Now here is a new problem: where do I find a simple as possible but still working schema of a circuit like this? This forum is quite big.
I think a thread dedicated to working schema's with comments (but no discussion at all) would be great. If an error is found or info is to be added to a schema the post is edited rather than a new post is added.
Originally Posted by Sephiroth View Post
nilrehob - I am almost 100% confident that the passing magnets actually take energy away energy from electrical output and does not add to it.
This is most surprising to me. I must find a way to check this.
Is this contradicting what boguslaw wrote?
The transient spike preceeds the flyback.
How do I generate and detect this? Do You have a osc-scope-shot?
Originally Posted by Aaron View Post
Right, if you zoom into the spike close enough, you will see it is a triangle with some width getting wider towards the bottom. However, there are spikes like this but also true impulses without the current...this is firmly established.
How do I generate and detect this? Or, where can I read about this?
There is a way to have current in the coil AFTER
you remove the input power.
Again, a thread with working schema's accompanied by comments on how to make it work would be must useful, like a patent-repository (but without its restrictions of course), and no discussions. Not only big apparatus but also small parts to show how a specific concept works (like how all kinds of EMF and all kinds of spikes works).
Unfortunately it seems like the forum-software is compressing attached pictures, but that can maybe be changed?
Hob Nilre
