Here is what I've came up with on the "Tropical Year Frequency" Circular Arcs I'm looking "Down" on the North pole with the Earth is running CCW with three hundred and sixty (360) CW magnetic flux circular lines penetrating the Earth three hundred and sixty times (360) places around the "Equator" each "Circular Arc" in sets of three (3) phases A, B, and C offset one (1) degree in sets of three (3). There are one hundred and twenty (120) sets for each of the three (3) phases A, B, and C. This is a change as you will see to finalize this theory of "Teslas" wireless transmission. ( everything in multiples of three )
The "Tropical Year Frequency" Circular Arcs ..... it is similar with quantity of arks in a multiple of three to cover exactly all existing explained and unexplained areas of interest with large grounding rings or pyramids around the world either ancient or new ran by government agency's.
The proposal is the same only changed by the quantity. There are one hundred and twenty (120) sets of three (3) circular arcs for each phase or 120 degrees, the three circular arcs per set are connected in a "delta" or "star" more commonly known as a "Y" configuration A-B, B-C, and C-A inside the earth. The one hundred and twenty (120) Y connected sets of three (3) circular arcs are totally separate being one degree (1) apart for a total of three hundred and sixty (360) degrees (Tesla Poly). This would verify 100% of what Tesla said that was possible to send radio waves, electricity, video or photos and energy waves and more as there are one hundred and twenty (120) Y connected sets of three (3) circular arcs to work with as long as you have a "EARTH" ground to gain access on land with each of the one hundred and twenty (120) per phase Y connected sets of circular arcs.
As far as I can determine there are only four (4) sets being used as follows -
The first "Omega" ground reference building at -
00 28' 02.50"S, 90 17' 01.71"W
pointing to in rock - W 90 degrees 30' on the Equator at "flux line" entrance negative point -
W 30 degrees 30' Phase A center of circle
E 90 degrees 30' Phase B center of circle
W 150 degrees 30' Phase C center of circle
The second connected set tied together is "Wardencleffe" Laboratory facility in New York, Camp Upton "Brookhaven National Laboratory the Pyramids in "Gazi" lower Chile and Argentina -
W 24 degrees 00' Phase A center of circle
E 94 degrees 00' Phase B center of circle
W 144 degrees 00' Phase C center of circle
The Third set ties Teslas sites in Colorado Springs, Peterson AFB, Fort Carson and protected Pyramid complexes on base -
W 35 degrees 00' Phase A center of circle
E 85 degrees 00' Phase B center of circle
W 155 degrees 00' Phase C center of circle
38 40' 44.13"N, 104 37' 43.16"W
It also connects the seven pyramid accelerator entrance point found by "Rick"
located in Mexico -
19 18' 06.00"N, 99 10' 54.00"W Cuicuilco Pyramid, Mexico City
19 03' 29.00"N, 98 18' 06.10"W Great Pyramid of Cholula, Mexico
18 16' 48.29"N, 93 12' 06.31"W Comalcalco Pyramid, Tabasco, Mexico
18 06' 19.41"N, 89 48' 38.98"W Calakmul Pyramid, Campeche, Mexico
17 02' 40.00"N, 96 46' 05.20"W Monte Alban, Oaxaca, Mexico
20 21' 34.00"N, 89 46' 17.01"W Uxmal Pyramids, Yucatan, Mexico
20 40' 58.44"N, 88 34' 07.14"W Chichen Itza Pyramid, Yucatan, Mexico
The last set is used by "Cern" in Switzerland and France -
W 38 degrees 00' Phase A center of circle
E 88 degrees 00' Phase B center of circle
W 158 degrees 00' Phase C center of circle
All perfectly fit and are in total alignment and within all elliptical circular "flux" line widths using the following lengths -
Earths Circumference is 40,075.02 Km
Y connected elliptical circle arks every one degree, 120 degrees per phase
Elliptical circle diameter - 13358.34 Km
Elliptical circle radius - 6679.17 Km
Flux width 10 to 15 miles maximum, centered in the elliptical circle ark.
Glen
