  #2055 (permalink)
Old 12-26-2008, 05:51 PM
ren's Avatar
ren ren is offline
Senior Member
Originally Posted by sucahyo View Post
Hello,
I am a beginner, I want to know if anyone ever use wall electricity for lighting up the CFL in the same way anyone use 12VDC?
Would applying 220VAC to the circuit will work if we replace the relay with something like Omron MK3P-I (rated 250VAC, 3 sync contact) ?
And would it be safe for other electronic attached to wall electricity?
Its done all the time. HV/HF from a tesla coil designed to run off mains power. Most designs of this measure usually opt for maximum power transfer for maximum arc display. You could use a neon sign transformer to step up voltage into the 1000's of volts, simple spark gap and tesla transformer.
