Originally Posted by sigzidfit
If a wind powered vehicle aint free energy I don't know what is.
I think compressed air could be OU.
Tesla made a turbine and a pump and said they ran like dc motors.
Dear Sigzidfit,
We have touched on this before in a number of different threads, but ordinary compressed air IS COP>1 if the HEAT of compression AND the compressed air are both captured and used efficiently. In commercial compressed air systems, usually the heat of compression (compressor gets very hot) is dissipated into the environment and only the compressed air is stored for use. This is why the efficiency of compressed air systems is usually considered to be about 50%.
What is interesting in these systems is when you place a second compressor INSIDE the tank of compressed air and insulate the tank. Then, when you further compress the compressed air, all of the heat of compression STAYS IN the tank and the energy is not lost.
So now, let's look at an automobile driving down the road, running on a tank of compressed air driving little wheel motors. At 60 mph (96kph) you have quite a bit of air coming at you. A carefully designed scoop funnel could "pre-compress" the air, say to 3 atmospheres, which is then compressed by an on-board compressor into the on-board tank. Since we are starting with air that is 3 times denser than normal, compressing it up to the tank pressure will only take one third as much energy.
The HEAT of compression from this process can then be used to further expand the compressed air as it enters the drive motors to produce even more mechanical energy to push the car along the road.
Some variation on this process will most likely extend the drive time of the compressed air system considerably, and possible lead to an understanding of how to extend it indefinitely.
You would probably want the car to have a very low "co-efficient of drag" so the air it is moving through does not slow it down.
Also, in keeping with the ideas of this thread, one of the wheels could be used to drive a blower to "pre-compress" the air even further from the scoop funnel before the on-board compressor. If you could get the air in the pre-compressor in-take zone to 5 atmospheres, the probability of continuous operation becomes quite high.
For those who still don't understand the physics of compressed air and its application to a "self-running" system, please study the information at this link:
Pneumatic Options Research Library: Home Page
Also, see this new page:
Equalization Engine, Luther's Secret for Self-Fueling Air Car
In any case, you should download the whole site (for free) and study the material in depth.
Enjoy,
Peter
