Originally Posted by Aaron
I would use a carbon resistor to see the difference of that as well but couldn't get any large enough diameter carbon rod to drill out and slip over the rod.
The sae here, I also did not find any carbon rods big enough in diameter to use for my Gray tube project. I had to work whit what I had - a carbon rod from a 1.5V cylinder battery, it is 8mm in diameter. But I think that Beshires1 is right, because you can get much bigger pieced of carbon from motor brushes
Also thank you for your summary, lust like Greg, I finnaly understood what you mean when you say that the high voltage actually goes through the diode. And the analogy with the compressed baloon is great, makes sense to me
This is exciting.
