Aaron you might try to source some DC electric motor brushes for a carbon block large enough to drill and use. Also you could modify a spark plug. By carefully cutting off the metal (threaded part and hex sides) the electrode is encased in ceramic. the electrode is in two pieces a hardened steel on the top (where the wire connects) and separated by carbon the electrode tip is I guess tungsten. (Its non Magnetic).
