tips of rods
Hi Beshires,
Both are cone shaped with rounded tips.
Supposedly Gray had rounded tips on both and that is what Bedini showed on his notes.
It will be a bit before I can run any tests to try what you mention to see what the effects are.
One thing I will definitely want to do is to blow torch melt some silver coating over both tips.
I would use a carbon resistor to see the difference of that as well but couldn't get any large enough diameter carbon rod to drill out and slip over the rod.
