Old 10-26-2019, 10:41 PM
Turion's Avatar
Turion Turion is online now
Gold Member
Parts
Bro Mikey,
You are correct. I threw in a rotor with magnets, I believe when I sent the oscilloscope. Might have been later. You CLAIMED to be replicating and I wanted you to have the best chance to be successful. Just like you CLAIMED you would reimburse me for the shipping on the oscilloscope. Neither time did I demand proof. Both times I took you at your word. My mistake now I require people to pay me for the shipping up front before I send them stuff. I paid a BIG shipping bill on stuff I sent to another country and never heard from that individual again, except to ask for MORE help, which I declined to give.
bi,
Just because YOU don’t believe the generator works doesn’t make it a non functioning device. Can the stock MY1020 turn the rotor with magnets on it at 2800 rpm on 24 volts? Look at the specs on the motor. Of COURSE it can. Is it able to do it for less than 12 amps with no coils in place? Even a fool would say it can.
Can a coil be built that produces 130 volts at 1.5 amps under load? You want to argue THAT point? I didn’t think so. Would 12 of them produce between the 1800 and 2000 watts I claim? Sure it would. No POSSIBLE argument there.
Your only possible argument is that when these component parts are put together, their interaction causes a change to one of these parameters.
1. Lenz causes the motor to bog down when the coil is under load. But delayed Lenz does not and THAT has been proven by lots of folks.
2, Magnetuc drag also causes increased amp draw of the motor but THAT is cancelled out by magnetic neutralization.
3. Constant switching of polarity in the iron core causes heating of the cores. But a water jacket APPEARS to solve that problem. I have built it. It works. Your BELIEF and insistence does not compare to my KNOWLEDGE. When I get it back together I will show inputs and outputs to some folks. But never YOU bi. You are right where you deserve to be. In the dark. LOL.
