Old 09-26-2019, 09:27 PM
soundiceuk's Avatar
soundiceuk soundiceuk is offline
Gold Member
Here is the axle and separating washer with the discs ("runners") hidden:
Here are some more pictures for clarification.
The only feature missing is the tear shaped holes from the discs.
However using solid discs the machine becomes a compressor. The quietest compressor in the world!
Here are shots of the individual layers:
Centre volute layer:
Circular Groove layer:
Inlet Air Channel layer:
Air Bearing layer:
And thanks to Aaron Murakami I have the most detailed picture of the pump I've ever seen:
I managed to trace the whole design from this picture including side profile of volute, circular groove and inlet and outlets.
I made the volute section variable and the inlet section variable.
Tesla uses 11 discs and each disc has 3 holes (33).... Any amount of discs you use will be a multiple of 3.
The design is symmetrical and if the rotor is balanced it should remain perfectly in the centre.
A direct link to the CAD files:
https://www.dropbox.com/sh/mvx99hxxn...qKmMKU1la?dl=0
Tesla's atmospheric air bearings which were a big advancement of Westinghouses 1904 patent took a lot of experiments and R&D to understand, but the reality is simplicity and pure genius!
Without vacuum they won't work but if your rotor is built with reasonably tight gaps then even a low rpm rotation will make vacuum and suck in from any hole.
Using a household vacuum cleaner on the exhaust is guaranteed to levitate the rotor and get it spinning!
