Old 09-26-2019, 02:47 PM
soundiceuk's Avatar
soundiceuk soundiceuk is offline
Gold Member
Here are some pictures of the simplest four stroke cycle engine to ever exist.
Its is a 7 layer design, which allows the centre volute to be enlarged for a bigger rotor or the inlet ports to be enlarged to the required size.
I have designed this version to be the simplest for replicators.
It features Tesla's final atmospheric air bearing design.
I am currently manufacturing this in acrylic casing, stainless 316 axle and aluminium rotor so you will clearly be able to see the rotor spinning inside the pump.
It features a two piece pressed axle and sleeve design for 100% symmetry.
The 1mm chamfer is removed after pressing to complete the symmetry.
