Old 07-21-2019, 07:23 PM
soundiceuk's Avatar
soundiceuk soundiceuk is offline
Gold Member
Where did I get the name "Thermodynamic Transformer" from?
US Patent 1,061,206 - Turbine
"In the drawings, therefore, I have illustrated only the form of apparatus designed for the thermo-dynamic conversion of energy, a field in which the applications of the principle have the greatest practical value."
"7. A thermo-dynamic converter, comprising in combination a series of rotatably mounted spaced disks with plane surfaces, an enclosing casing, inlet ports at the peripheral portion and outlet ports leading from the central portion of the same, as set forth."
"8. A thermo-dynamic converter, comprising in combination a series of rotatably mounted spaced disks with plane surfaces and having openings adjacent to their central portions, an enclosing casing, inlet ports in the peripheral portion, and outlet ports leading from the central portion of the same, as set forth."
British Patent 24,001 - Improved Method of Imparting Energy to or Deriving Energy from a Fluid and Apparatus for Use Therein
"The greatest value of this invention will be found in its use for the thermodynamic conversion of energy."
Canadian Patent 135174 - "Fluid Propulsion
"The greatest value of this invention will be found in its use for the thermo-dynamic conversion of energy."
"11. A thermo-dynamic converter comprising a shaft, a plurality of disks spaced thereon, an inlet for the motive fluid at the periphery of the disks and tangential thereto, and an outlet at the central portions of the same, as set forth."
British Patent 179,043 - Improved Process of and Apparatus for Production of High Vacua
"In the development of power by thermo-dynamic primemovers, as steam engines and turbines, a low back pressure is essential to good economy, the performance of the machine being increased from fifty to one hundred per cent. by reducing the absolute pressure in the exhaust space from fifteen to about one pound per square inch."
British Patent 186,084 - Improved Process Of And Apparatus For Deriving Motive Power From Steam
"at the same time increasing the efficiency of thermodynamic transformation."
"The hereinbefore described process of thermo-dynamic transformation of energy which consists in admitting steam to a turbine nozzle, aspirating by the suction thus created hot products of combustion through a heater, superheating the steam by them and discharging them at high velocity and in a direction parallel to the steam-jet upon the rotor, as described."
British Patent 186,083 - Improved Method of and Apparatus for the Economic Transformation of the Energy of Steam by Turbines
"The chief object of my improvements is to increase the efficiency of the existing steam power plants and thermo-dynamic transformers operated therefrom"
British Patent 174,544 - Improvements In Methods Of And Apparatus For The Generation Of Power By Elastic Fluid Turbines
"In the first place my turbine is exceedingly suited for very elevated temperatures and also high pressures, while the Parsons excels in the efficiency of the thermo-dynamic transformation at moderate temperatures and low pressures."
"1. The improved method of thermo-dynamic transformation which consists in converting a part of the heat energy of an elastic fluid by disc friction and a further part by blade action, substantially as described."
