Old 07-05-2019, 11:52 PM
Solarlab Solarlab is offline
Member
Hi Cadman;
Great work and very interesting, thanks!
The links below might be similar to your concept development and may possibly contain some valuable design and construction insight and info.
Design and Construction of a Hydraulic Ram Pump
(including a bit of history and analysis)
Shuaibu Ndache MOHAMMED
Department of Mechanical Engineering,
Federal University of Technology, Minna, Nigeria
Design and Construction of a Hydraulic Ram Pump from Leonardo Electronic Journal of Practices and Technologies
Abstract
The Design and Fabrication of a Hydraulic Ram Pump (Hydram) is undertaken. It is meant to lift water from
a depth of 2m below the surface with no other external energy source required. Based on the design the
volume flow rate in the derived pipe was 4.5238 ◊ 10-5 m3/s (2.7 l/min), Power was 1.273 kW which results
in an efficiency of 57.3%. The overall cost of fabrication of this hydram shows that the pump is relatively
cheaper than the existing pumps.
Keywords
Hydram; Pump; Volume Flow Rate; Power; Efficiency; Impulse Valve; Delivery Valve.
Home Built Hydraulic Ram Pumps
http://www.inthefieldministries.org/...am%20Pumps.pdf
"Complete detailed and illustrated instructions from locally available pumping parts - 1" Hydraulic RAM"
How to build a RAM PUMP
French River Springs
Published on Jul 7, 2018
https://www.youtube.com/watch?v=enBEMgDR3-A
How to Make a Large Size Free Energy Water Pump - Ram Pump
Tradisional Channel
Published on Dec 28, 2018
https://www.youtube.com/watch?v=Esln877z4IE
Hydraulic RAM Pumps - Amazon (wxamples)
Small - $125US - - - Large - $185US
https://www.amazon.com/Hydraulic-Ram.../dp/B072J2Q7L6
Regards and good wishes, SL
[also posted these a few days back on OU but it's still waiting censor/moderator approval ]
