Old 07-01-2019, 03:50 AM
spacecase0's Avatar
spacecase0 spacecase0 is offline
Senior Member
Originally Posted by Pot head View Post
Howdy from redneckville.
This thread is for coil builders and designers.
Everyone is invited to learn.
My question: Does a coil with 8 strands, plus a smaller trigger strand which is used separately, put out more volt/amps than each of the 8 independently rectified strands?
Will I get more from each strand independently rectified or from a very large strand, i.e., the 8 soldered together?
if you have higher frequencies, the multiple strands will work better than a solid wire that is the size of the bundle.
but that only applies to frequencies that are likely well higher than you are using, so I don't think it matters to what you are doing.
