Old 05-17-2019, 02:08 PM
OldTimer OldTimer is offline
Junior Member
Right. Now I have even less idea what the heck is going on than before. The results are:
Without the cap and without charging batteries:
Neon on straight away, voltage base/emitter 1.3, then settled slowly down to 0.59v, with neon going off at around 1.2v
Without the cap and with charging batteries hooked up: neon does not light up, voltage base/emitter 2.6, then settled slowly to 0.59v
With new cap and without charging batteries: eehhhmmm. I got -1.3 volts, with neon coming on sometimes and sometimes not, and then the voltage across base/emitter flipped from negative to postive and settled on 0.2v... ???
With new cap and with charging batteries: I got 0.2 volts stable, but it seemed like the transistor was heating up, and before I could do anything else, the transistor starting smoking so I yanked the cables loose....
And that's where I'm at now... no clue...
Cheers,
Paul
