Old 05-16-2019, 08:16 AM
BroMikey's Avatar
BroMikey BroMikey is online now
Platinum Member
Originally Posted by SkyWatcher View Post
Hi bromikey, thanks for the positive words.
I don't have smaller magnets on hand, though I can always build another rotor later.
I picked up some parts from hardware store to make the motor arbor.
Unfortunately, the threads on the top part of the motor I was hoping to use. are reverse thread, so the nut coupler can't just be threaded on.
So I found a 3/8" coupler that is fairly snug over most of the shaft, so I bored a set screw hole to make contact with flat part on shaft, just need to pick up a tap and die kit to tap the set screw hole.
Was also working on the PWM motor controller circuit, it works well.
Here is the circuit.
peace love light
Yes Sir got to do it eventually get set up with taps and dies plus the
coupler we all figure out just like you. What I like a lot about you is
your ability to circuit. If you can do it, other can too. Gotcha a pulsed
motor now.
Sweet, see each man has a strength.
